Neon Indicator Wiring?
theSeeker
Post by theSeeker »
Oops, I didn't pay attention to how the neons were wired on my DR201. Do they have specific polarity? For reference, I can see which wire is attached to the internal resistor.
Re: Neon Indicator Wiring?
They're A/C lamps, so no polarity is involved. Here's a pic from my SA212, before I replaced its neons. Should be similar to your DR201.
EDIT: Note that my SA212 had a Polarity switch, so your wiring will be slightly different.
SA212 neons.jpg (287.1 KiB) Viewed 930 times
theSeeker
Post by theSeeker »
Ah doof! Pre-rectifier, that makes perfect sense. :oops: I should have thought it through, Thanks Dave.
riba2233
Post by riba2233 »
You can see it all clearly in this picture:
http://img191.imageshack.us/img191/1594/19062011194.jpg
Dave's combo has somewhat different wiring.
