Neon Indicator Wiring?
Oops, I didn't pay attention to how the neons were wired on my DR201. Do they have specific polarity? For reference, I can see which wire is attached to the internal resistor.
Re: Neon Indicator Wiring?
They're A/C lamps, so no polarity is involved. Here's a pic from my SA212, before I replaced its neons. Should be similar to your DR201.
EDIT: Note that my SA212 had a Polarity switch, so your wiring will be slightly different.
Ah doof! Pre-rectifier, that makes perfect sense. I should have thought it through, Thanks Dave.
You can see it all clearly in this picture:
http://img191.imageshack.us/img191/1594/19062011194.jpg
Dave's combo has somewhat different wiring.
