Good afternoon, Dave...
Thanks for the reply; those are indeed the questions in my mind...
OldSchoolDave wrote:Does it work transparently, without effecting tone?
If it works as per the 'blurb', it shouldn't 'tonally' affect the amp, except for ensuring the closest bias possible, so perhaps less subtle harmonics, more 'hifi-like' (that's what I'd want for bass...), but the bias 'imbalance' can be adjusted, it seems, so that could be good for Townsend-like guitar..?
Is there enough clearance inside the amp cab for the additional socket height (some are pretty tight already)?
There should be room in a DR203; combos could be limited..? The race would be on for shorter tubes..!
Will the thing stay put in transit, in a velcro'd semi-permanent installation?
In my very domestic setup,this shouldn't be a problem; I suppose a more solid fixation, such as screwing to the inside top, wouldn't destroy the vintage value too much, if done cleanly. For 'pro' use, I don't imagine there's
that many collector amps out there as rented backline.
How much heat does it put off and would that be detrimental to the amp?
It could be the opposite; apparently the valve heat output is lessened, and the total head heat output could be reduced, even with some dissipation from the unit (at least that's what I understood...)
Can it boost as well as cut?
If it's controlling the valves completely, I assumed that it could increase as well as decrease the bias, as long as the result was not out of tolerance (such as a duff valve...)
Why don't you buy one and let us know the answers
Why not, indeed? Still no idea on price, but sooner or later I would be looking for a quad of KT88's; acquiring singletons and using this unit for bias optimisation could recover the cost of the unit, seeing the price of matched quads (or pairs of pairs...). I've not had the amp long, and it's not 'hammered' daily, so I'm not needing to swap out right now, but that's when to start preparing, isn't it? My bassman is closer to revision time, but then we're back to 'headroom' problems (physically...). As to the Mesa, it has an octal tube set, and space is more than tight in the 'rack' head.
I'm principally a drummer (amateur, now...), so my budget also has to be stretched to include cymbals (
any 602's out there going cheap..? No..? Didn't think so...); my guitars need upkeep (
and keep reclaiming stablemates..!), the house has to be repainted, tyres for the car... We all know the score... If I go for it, I'll inform, but it wouldn't be this quarter, anyway, so there's no rush.
Have a good day.
Dad3353 (Douglas...)
