heres a slideshow with many pics after i cleaned the chassis and trannys, the guts have just had a brush off to get rid of the cobwebs. i used mild soap and a bit of wire wool on the chassis and a barely damp sponge on the trannys/caps.
http://s27.photobucket.com/albums/c160/ ... =slideshow
the voltage and impedance selectors had lost all the bacolite and the output tubes were shot... it was a bit of a job to get out of the case and the fuses in it were not correct by a mile so i hope those transformers are still good. theres no way i am hacking this when i get it working again... i'll let you guys have a mooch first before i get it working. the cans dont look as bad as my dr103. and there are pots and caps dated 68. rear badge says dr109.... i thought it was an odd one. serial number 444
hiwatt quality throughout from Dave Reeves garage.
