Hello,
I recently checked capacitor values of my 1975 Hiwatt SA212, because I want to change them soon. I noticed odd cap values different than the values mentioned on the net. The axial cap is 250 uf 64V and the 3 caps are 200 uf 350 V the rest two have the same values as the internet values. Should I respect the values on the amp and change them with the equal values or should I change recommended values on the net? Anyways what would be the difference if I install equal values or not?
SA212 Odd Capacitor Values?
Re: SA212 Odd Capacitor Values?
The bias cap value is not critical. Anything 50uF or up will work fine here.
The 200uF are just pre-standard days values. The closest standard value is 220uF. Note that in those days the typical tolerance for electrolytic caps was +40/-20% (!), so those may well be 220 (or 180 or 230...) uF caps in reality.
Thank you Mark .
Which one is best to go for the bias cap with the least compromise? I think I have Hiwatt OCD
220 uf 63V : http://www.audiocap.co.uk/ft-axial-220u ... -412-p.asp
470 uf 63V : http://www.audiocap.co.uk/ft-axial-470u ... -417-p.asp
150 uf 100V : http://www.audiocap.co.uk/ft-axial-150u ... -414-p.asp
330 uf 100V : http://www.audiocap.co.uk/ft-axial-330u ... -415-p.asp
220 uf 350V : http://www.audiocap.co.uk/ft-a221350250 ... m-51-p.asp
150uf/100v.
Agreed.Dr.HIWATT wrote:150uf/100v.
