I was setting up to playing a gig with my 1981 2 hole Hiwatt Dr-504 and after a little warm up and flick of the standby no sound was coming out of cab.
Everything was plugged in and set properly I knew that for sho.
My quess is the master volume pot went out?
Any quess as to what happen- before it went out I heard a little fizzle not sure what that was.
The long and skinny of it is that it remained power so I am guessing its not fuses.
'81 DR504 Powered but No Sound
Re: '81 DR504 Powered but No Sound
it is most likely a tube that died.
I would guess the phase inverter first, but it could be any of them.
Not likely a pot.
Not likely a pot.
Nope changed all tube EL34's and all pre-amp tube still no luck or sound.
Speaker fuse go bad? Need a meter to verify continuity.pjking81 wrote:Nope changed all tube EL34's and all pre-amp tube still no luck or sound.
If you haven't already, check the HT fuse. If it is blown, the pilot light will come on, but no sound will come out.
http://hiwatt.org/tech.html
I changed the V1 (HT) fuse and no luck.
Hmmmm. Pull the impedance selector out and check for corroded contacts. I've had those short out due to oxidation.pjking81 wrote:I changed the V1 (HT) fuse and no luck.
Have you checked the Phase Inverter (middle of the 3 preamp tubes), as Dr.HI-TONE suggested?
Turns out the fuse I was originally given to replace the one that burnt out was faulty.
I went back to the store and got another and like magic my Hiwatt lives again!
Well it wasn't just that, I went through two fuses after the first went I had a pair of Winged 'C" in there, threw in the fuse and bang it works, and then I swapped the tubes for a pair of JJ's and the it blew the fuse. I got another fuse and a fresh pair of tubes (wait don't crinch) Mesa Boogie EL34's, threw in the second fuse and it works again and still has.
And to think I had it up for sale at a $1,000 (originally paid $1,350 plus shipping) and a tech wanted to buy it and so he looked it over and told me that I just need a fuse.
He knew that if it was repaired that my asking price would go up, so he saved me from selling.
Phew that was close!
