Seen this mentioned a few times, do we know if it was a factory mod or available to order?
I've seen a hole pre-cut in an early 74 chassis (presumably for the switch) which was then covered by the serial plate.
Any body else seen this?
Half power switch
Half power switch
Re: Half power switch
Sorry forgot to ask exactly how the half power was achieved. What did the switch do?
the hole was present till the mid 1970's
when activated the switch lowered via a large resistor, the voltage on the plates
Thanks for that, was this an option available when ordered or was it a special or even a later factory mod do we know?
It was an option for new products early on. I think it was phased out as it is very hard on the tubes unless you place the amp on standby before switching.
I would have to guess that it simply wasn't worth the trouble that came with users flipping the switch repeatedly without using the standby switch.
But that is just my theory.
