The high voltage fuse of my DR103 went and my tech says it's about time to change the tubes. I need re-tubing advice. Here is what I have in mind, after reading:
NOS power tubes: NOS Svetlana SED EL34 Winged C (4X) with "burn in" for matching. They seem like a good option.
NOS preamp tubes:
(a) two separate matched pairs of Mullard ECC83
(b) two separate matched pairs of Valvo ECC83 with 45 degree getters. The getters seem like a good thing.
(c) all 4 matched pairs of Mullard or Valvo ECC83 --- worth the ludicrous prices? I actually found both of those on ebay, but I got outbid on the last seconds; sometimes it's good not to get something you want!
Now, the laughable part: do these really matter for a good reason or it's pure audiophile corksniffing:
- same factory plant?
- same matching IDs?
- whether not all 4 tubes are "matched"?
Maybe, for a technical reason, a mix of different tube designs is better for different locations in a Hiwatt; I don't know amps' inner workings in great depth.
Thanks and best regards!
