stereo HIWATTs
stereo HIWATTs
Hey guys,
I'm looking to double the mayhem and go with a stereo HIWATT rig...
Never really tried this before - would it be best to go with matched heads (2 x DR103) or a DR103 + DR504 mix?
Opinions?
Opinions?
Re: stereo HIWATTs
Why not 2 x DR201 ?mikhailwatt wrote: - would it be best to go with matched heads (2 x DR103) or a DR103 + DR504 mix?
Are you going to do one clean, one wet or are you looking for a fairly symmetrical sound? If the latter, it might be helpful to have the same heads on each side. But, not absolutely necessary. You should be able to dial in a DR103 and a DR504 to a pretty good match.
But......aren't you near a seismic fault ?
Re: stereo HIWATTs
OldSchoolDave wrote:But......aren't you near a seismic fault ?
They'd be set up in a symmetrical "semi-wet" stereo rig... occasional analog stereo chorus, 'vibe, and delay ahead of the amps.
Any really heavy time-based f/x would probably still go post-amp - I'll have to see how much "engulfication" is attainable with "only" the dual half-stacks and stompboxes.
Re: stereo HIWATTs
The latest incarnation of terror :
<--- DR504 #14872 ("converted") w/ SE4123 #6494 (2 Fane 122231, 2 Fane 122142)
--->iWATT DR103 w/ SE4123 #8263 (Fane 125114)
Re: stereo HIWATTs
NICE !
Re: stereo HIWATTs
Lovely!
Nothing better than some HIWATT Goodness!
Re: stereo HIWATTs
pssst... HIWATTuser1... the Dejavibe is STEREO!
TC Nova delay<--TC Nova modulation<--Dejavibe<--OCD<--RTO
Need to build a pedalboard...
Re: stereo HIWATTs
Very nice Mike!!! How do you like Nova's?
Re: stereo HIWATTs
I spent a good half hour at GC, testing the delay for transparency. It doesn't mess with the basic guitar-amp tone much at all... unlike the Line6 DL4 which sucks out all the low end punch.JC103 wrote:How do you like Nova's?
The delays are nice - I really like the analog setting with a little bit of coloration/warble. The modulation f/x are quite good, although I might add an analog chorus later.
You have to do a little tap dancing with them to change presets on the fly, but I pretty much leave the delay on all the time, and kick in the occasional chorus or phase shifter.
Re: stereo HIWATTs
Great you noticed this too? I used to own 2 DL4's but them promptly sold them once I figured out what was sucking all my low end away.mikhailwatt wrote:unlike the Line6 DL4 which sucks out all the low end punch.JC103 wrote:How do you like Nova's?
Re: stereo HIWATTs
Keeley does a mod for the DL4, don't know if it fixes the low end disappearing act, though.keira wrote: Great you noticed this too?
The wait time might be really long - I read that their shop burned down a few weeks ago.
