Question: 2 valves in a DR-103
If I were to run a DR-103 with two of the power valves pulled and half the output impedance, wouldn't this pretty much sound (volume wise), and preform exactly like a DR-504 ? After looking at the schematics on MHuss's site, it looks to me like they would be approximately the same. Thanks for the input.
-lffish133
Re: Question: 2 valves in a DR-103
Pretty close. Never tried the two side-by-side, though.lffish133 wrote:...exactly like a DR-504 ?
Keep in mind that the output transformers are different between a DR103 and the DR504. So, you'd have an "oversized" transformer working at half capacity instead of a "perfectly sized" transformer working at 100%.
It should sound close. I haven't A/B'd them before either, but maybe we can at the convention for scientific research purposes?
-Clayton
-Clayton
Yeah I was thinking about the output transformer thing too, I'm sure they wouldn't be exact, but I'll bet they would be dang close, that would be interesting to A/B them side by side and listen for the differences.
-lffish133
I've put 4xEL34, 2xEL34, 4x6V6 and 2x6V6 in my '103 clone, and it always sounds good! The 4x6CA7 option is the one that puts hair on your toenails, however!
I guess this is directed at Mark or anyone who has used 2x6CA7, 4x6V6 or 2x6V6 in a 103. Were there mods required other than bias? Any harm running 4x6V6 for months / years?
Sorry if I am asking dumb questions but I haven't gotten a handle on output tubes and OTs.
Thanks,
Kenny
Thanks,
Kenny
Only use the JJ 6V6s, as normal ones can't handle the high voltages.
Otherwise, yeah, just a bias tweak and you're good to go.
