Could be a loose back panel vibrating against the center post. Try pressing on it with your knee (or get a volunteer) while you play the low notes to check.Gomez wrote:I noticed there's some buzzing in the cab when playing low notes... could it be the speakers or is it more likely to be the actual cabinet?
Can someone help me identifying this cab?
Re: Can someone help me identifying this cab?
Can't quite make it out on the picture .Gomez wrote: I think it's in series.
Again, if the positives and negatives of both speakers are hooked together, it's parallel.
