Vintage HIWATT Convention 2010
Here's the place to discuss Vintage Hiwatt Conventions; past, present & future!
Zells
Re: Vintage HIWATT Convention 2010
Post by Zells »
This is a very cool early Hiwatt with serial # in the 4XX range (1968?) with no master volume. Notice the odd placement of the Bulgin socket, the smaller vent on top, and the longitudinal stripes on top. Wait, why is the voltage tap selector pointing to '225V'?
Zells
Post by Zells »
This a 7XX serial # DR103 built in 1969 and used by the band Soft Machine. Is that a slave jack next to the serial tag?
Zells
Post by Zells »
1969 Hiwatt CP103. It has the four input volume knobs and lacks a 'middle' tone knob just like the CP103 amps used by The Who. There seems to be no vent on top and no bulgin socket.
Hiwatt Bob
Post by Hiwatt Bob »
thanks for the pics Zells!
who's Plexiglass Hiwatt is that?
Hiwatt Bob wrote: who's Plexiglass Hiwatt is that?
That now resides in its rightful place: Hiwatt Valley!
Zells, several of Dr.Hiwatt's amps run at 225v. He's got a voltage regulator for that very purpose.
Zells
Post by Zells »
OldSchoolDave wrote: Zells, several of Dr.Hiwatt's amps run at 225v. He's got a voltage regulator for that very purpose.
Do these amps run properly at 225V only, or is this voltage chosen as a matter of preference?
I have a handful that do not have 105, or 115 taps. only 225, 235, 245.
There is no tonal effect on running an amp on 125 v. 225 unless there is a descrepency between the wall voltage and the tap on the transformer.
ie. an amp set at 115v with voltage at the wall supplying 126v. compared to an autotransformer deliverying a steady 225 to an amp set at 225.
Zells
Post by Zells »
Dr.HIWATT wrote:I have a handful that do not have 105, or 115 taps. only 225, 235, 245.
That makes sense for an exclusively European customer base. I'm guessing that these amps are all pre-1970.
yes, most of mine are 1970 or older.
Dr.HIWATT wrote:...compared to an autotransformer deliverying a steady 225 to an amp set at 225.
Hmm, have you ever tested these (actual output voltage under load)? Or do you just "trust them?" :twisted:
I tested one of the two a year or so ago. it was accurate.
buster
Post by buster »
Glenn Cornick messing about.
Glenn's invisible bodied guitar.
Some of the gear on show
I KNOW you took more pictures than that, buster! Let's see 'em!
How was the flight home?
buster
Post by buster »
The flight home was very pleasant thanks Dave.
Mark looking for the rest of the band.
There they are.
buster
Post by buster »
Dave heading for his "special" room in the corner of the hall.
Another Hi-Tone display shot.
Dave and Glenn Cornick on a boat after the convention.
