not a matched pair unfortunately but the real deal nonetheless, 1's a 72 and the other a '71.
they both sound MASSIVE brilliantly clear an all the usual phrases etc, but small prob with the '71 which has a slight distortion/buzz to it.
HELP!
with the amp at real low vol u cant hear it but turn it up slightly an u can hear it creeping in esp on a low open E chord, u can still hear the clean guitar same as the other speaker, but it has this slight distortion in the back ground.
this 1 has a slightly lower ohm rating than the other at 13.1 compered to 14.1
i have taken it out of enclosure in case it was that, nope still doing it.
there is no damage to it at all, but I'm thinking the voice coil might of got a bit nudged during transit (it was packed properly an everything) or it was already out of centre & the seller dint no or dint mention. after suspecting coil rub i had a look around on the site an i reckon that's what it is, unless any 1 thinks different?
i have equally pressed down on the cone sides an it does grate a little but only when pressed quite far down.
had a look at the doc voice coil rub fix, is that the only way to fix this prob? i really dont want to cut away the lovely alu dust cover! is there another way?
is there a way of maybe loosening the mag screws an I've read somewhere putting a little acetone/nail varnish remover on the spider, leave it a bit to reset then tighten up?
i know its often very hard to diagnose problems over the internet but hopefully there r some experts out there that know exactly what it is.
thanks
