New JJ 6CA7
New JJ 6CA7
I don't know if any of you guys have tried these yet, but I just got a quad.
I tried them in a 1971 DR103 immediately after playing the amp with a set of JJ E34L's.
Initially the amp is louder with more bass. I only had a few minutes to try them, but I will post more impressions later.
They appear to be a rugged tube. pictured next to a Mullard XF2.
Re: New JJ 6CA7
Looking forward to your observations. Beat the heck outta those, if you can, please. Need to know how reliable they are as well as how they sound.Dr.HIWATT wrote: Initially the amp is louder with more bass. I only had a few minutes to try them, but I will post more impressions later.
Re: New JJ 6CA7
I'll need to have the house to myself for that!
Little Deuce may get blown out of his swing.
Re: New JJ 6CA7
I have a set of NOS Sylvania 6CA7s that sound KILLER in a DR103. It'd be cool if the JJs were built similar to the originals.
The 6CA7 was a large and rugged US EL34 clone, using beam plates to get around Mullard's screen grid patent. Other notable beam power tubes include the 6L6 and KT77. The beam tetrode is more efficient than a true pentode, because you don't have to supply the screen current of a pentode like the EL34 (about 10% of the plate current).
Re: New JJ 6CA7
One of the "secrets" to one of EVH's sought after sounds (in "M" amps, of course).mhuss wrote:I have a set of NOS Sylvania 6CA7s that sound KILLER in a DR103.
It certainly would be!mhuss wrote: It'd be cool if the JJs were built similar to the originals.
Re: New JJ 6CA7
I'd like some 'feedback' about these too
Re: New JJ 6CA7
Hmmm,I wonder if the DR half-power switch would work with beam tubes, since it works by limiting screen current.
Re: New JJ 6CA7
Mark, I think you are wrong. Beam tetrodes have the same screen grid (second grid) as pentodes, the difference is between third grid, pentodes have true grid, while beam tetrodes have beam forming plate instead of true grid.
From radiotron handbook:
Re: New JJ 6CA7
The beam power feature replaces the suppressor grid, so while the tube functions similar to a pentode, it remains a tetrode. The suppressor grid functions at ground potential, so it shouldn't affect the operation of a half-power switch.
As such, a 6CA7 is functionally comparable to an EL34, but isn't a clone either in construction or sound.
Popular beam power tubes for guitar amps include 6L6, 6CA7, 6550, and the entire kinkless tetrode (KT) series (KT66, KT77, and KT88).
Re: New JJ 6CA7
Darn. There is a first time for everything.riba2233 wrote:Mark, I think you are wrong.
You are both correct, of course. The suppressor grid is the replaced, patented feature. However, the beam tetrodes are still slightly more efficient than pentodes, all other things being equal.
That will teach me to post after beers.
Re: New JJ 6CA7
Re: New JJ 6CA7
I have beat on them a bit more this week.
no redplating or break downs.
They certainly have a strong bass to them. I would describe them as "BOLD".
I would think them excellent for bass use.
I will update again after more beatings!
Re: New JJ 6CA7
Maybe I can help you with that on Sunday?Dr.HIWATT wrote: I will update again after more beatings!
Re: New JJ 6CA7
OldSchoolDave wrote:Maybe I can help you with that on Sunday?Dr.HIWATT wrote: I will update again after more beatings!
Of Course!
Re: New JJ 6CA7
My humble observations after a brief test drive of the JJ 6CA7's:
Dr.Hiwatt used the term "bold". I'd say "forward", "up-front", perhaps even "in your face" to describe the mid-range punch of these tubes. Not harsh, but very aggressive.
I'm sure these tubes will gain some fans. My particular tastes yesterday preferred EL34's "warmth" instead.
