Buzz/Fizz from any overdrive
Posted: Sat May 26, 2012 9:30 am
Hi guys,
Last week I got a 1978 Hiwatt DR103 2 Input and a 1977 SE4129 Cab with Fane 122667 speakers.
When I tried it out before buying I only played it clean as I live in an apartment and it was 9pm. It sounded fantastic and really quiet so I went with it.
A few days later I cranked the normal and brill channels with the MV down pretty low (see above mention of being in an apartment) and noticed that there was a buzzing transistor radio like sound that was completely killing the good tone of the amp. I did some research and discovered the Fizz issue. I've considered modding it to the mid 70s spec (removing the bridging wire on v2 and soldering 2 resistors in) but thought that if I was planning on using pedals mostly then it won't be that much of an issue. That was until I put an early 80s Tube Screamer and a Jam Pedals Red Muck into it. Essentially I discovered that no matter what volume the channels and MV are on, any distortion sets off the transistor buzz, effectively ruining the pedal sound. It really does sound awful doing anything besides clean.
Is this what the fizz problem does? I thought it was just from getting the natural valve distortion, not pedals.
If it is the fizz issue then I will be modding it ASAP however I thought I'd check here to see what you guys thought.
I have dreamed of owning a Hiwatt Custom 100 for ages, so I really hope this is an easy fix. I'd hate to have bought a complete lemon
I should point out that the previous owner has owned it since 1990 and has maybe played it for 3 hours in all that time. It is in fantastic condition and looks all original inside.
The pre-amp tubes are the original Mullard however the power amp tubes are a mix bag. 1 Groove Tube, 1 National, 1 labelled EL34 Made in GBR and 1 blank.
Also one tube has lost it's guide key however I have marked it and made sure it is installed correctly.
