It looks like.... but then again it doesn't.
It is a 12 inch. From what I can make out, the numbers that are there might say 12314 with the sixth one missing.
I can't quite make out the dating either. Does that say 31/78? A '78 cast frame? Or should that be 73, as in the shadow underneath?
This one puzzles me.
Does anyone have any idea what this is?
Vintage Fane... but which one?
- Fane 1.JPG (50.6 KiB) Viewed 2981 times
- Fane 2.JPG (35.59 KiB) Viewed 2981 times
- Fane 3.JPG (29.99 KiB) Viewed 2981 times
Re: Vintage Fane... but which one?
Yes. I have a cast frame HIWATT Fane dated 9/80. Some cast frames were used well into the stamped frame era.Fanedango wrote:A '78 cast frame?
Maybe it's just the picture, but that dust cap looks extremely large compared to the cone. Are you certain it's not a 10" speaker? Anyway, there are cosmetic similarities to a Crescendo, but I wouldn't venture a guess as to its actual characteristics...
Thank you for the response Dave.
The owner insists it is a 12 inch. However, I had the same reaction to the dust cap. I've never seen such a large dust cap on anything, not even on a crescendo.
I just noticed a second shadow underneath the /78 stamp: slightly further to the right. That one also looks to say 73.
One fine day in 1973/1978 the Fane stamp-chief had one too many pints for lunch. Maybe he and the dustcap-chief went out to lunch together...
Probably splitting hairs, but Fane's "3" has a distinctly flat top. Don't think the "8" is a smeared "3".
Have the seller take a picture with a measuring tape stretched across the gasket. I'm curious to see just how big it really is.
I'll ask.
Update: no reply.
Update: no reply.
