An Issue that need to be resolved
Posted: Wed Jan 22, 2014 4:31 pm
by Iliaspap
Hello,
I have an issue with my vintage 1974 DR103, when I turn on the mains switch, sometimes, not always, it turns on and immediately off.
If I turn off and on the switch a couple of times, it works.
- Is it bad Mains switch?
- Does it need recap (the amp is still in its very original condition).
- Is it bad contact in tube sockets?
- Nothing of the above? :)
Thanks in advance!
Re: An Issue that need to be resolved
Posted: Wed Jan 22, 2014 5:39 pm
does a fuse blow?
if not, I think the switch is faulty and needs replaced
Posted: Wed Jan 22, 2014 7:42 pm
by Iliaspap
Dr.HI-TONE wrote:does a fuse blow?
No, fuses are ok.
So, I am looking for new switches
Can I find completely identical switches in the emporioum?
Thanks for your quick answer Dr. ;)
Posted: Thu Jan 23, 2014 10:40 pm
by Fanedango
Posted: Fri Jan 24, 2014 11:11 pm
by Iliaspap
They seem 3-way switches, as I can see, they have 3 couples of pads.
I wonder if the old switch nuts match these switches from Hi-tone website:
http://shop.hi-tone-amps.com/Toggle-Swi ... -Arrow.htm
And maybe is a good chance to do a recap in the amp. All of the Can capacitors have a bulge sign, they need replace, don't they?
I would like to keep the amp as original as I can but I think the recap is mandatoty..
One last question, the Hi-tone recap kit as I can see in the picture, has 3x F&T at 385VDC, 1x F&T at 500VDC and 1xARS at 500VDC.
My Hiwatt has 3x RS at 350VDC, I assume that the voltage difference isn't important between the F&T and RS.
Posted: Fri Jan 24, 2014 11:25 pm
Iliaspap wrote: I wonder if the old switch nuts match these switches from Hi-tone website:
I have used those on vintage amps with no issues.
Iliaspap wrote:All of the Can capacitors have a bulge sign, they need replace, don't they?
For certain the green one, which has oozed some stuff through the relief bulge. Given the age, replacing all would probably be a good idea.
Iliaspap wrote: One last question, the Hi-tone recap kit as I can see in the picture, has 3x F&T at 385VDC, 1x F&T at 500VDC and 1xARS at 500VDC.
Higher voltage is actually better, in this case.
Posted: Sat Jan 25, 2014 12:22 am
yes, Dave is correct.
Posted: Sat Feb 01, 2014 10:23 am
by Fanedango
Posted: Mon Feb 03, 2014 6:40 pm
No, those are single-pole, single throw switches, the type mostly used by Fender. You want a double-pole single-throw switch, the type with solder terminals on each of the four corners.
Original Arrow DPST Switches
