SA212 1975 project
Posted: Wed May 07, 2014 2:59 pm
by issmol
Hi guys,
Managed to acquire this yesterday.. Needs a bit of TLC. (understatement...
Lots of questions coming probably regarding the missing pieces etc.
Loads of pics in the two links below.
http://s72.photobucket.com/user/philm0l/slideshow/combo
http://s72.photobucket.com/user/philm0l ... /combo%202
Re: SA212 1975 project
Posted: Wed May 07, 2014 3:03 pm
Nice score, albeit a bit abused(!). It's a shame about those valves.
The transformer looks a bit scary.
Posted: Wed May 07, 2014 3:50 pm
by issmol
Yes, its a great shame about the valves... But some you win and some you lose I suppose.
Its on the bench of my local tech at the moment to see how safe it actually is.... I would not have dreamt of switching it on.
(If the transformer looks scary to you Mark, can you imagine what it looked like to a complete novice like me.
Posted: Wed May 07, 2014 5:07 pm
issmol wrote: Needs a bit of TLC. (understatement...
But, definitely worthy of a restoration!
Keep us posted on your progress.
Posted: Wed May 07, 2014 6:37 pm
by issmol
Will do Dave.
It's been stripped back to a bare shell at the moment. Drivers have been cleaned very gently and I have a small hole in one of them that needs a repair before I test them.
The whole cab including the grille cloth needs a good clean and some glue repair to the Tolex.
ie... Lots of cosmetic things I can do whilst I await my techs verdict..
Posted: Wed May 07, 2014 6:51 pm
by teethdream
Too bad about the tubes. This guys seen a few battles by the looks of it, totally screaming for a restoration. Hopefully your tech gives you a good verdict!
Posted: Thu May 08, 2014 6:06 am
by issmol
Thanks teethdream.
The Tolex I can hopefully clean up without too much effort and I have some suggestions to help clean off the grille cloth but I could do with some advice regarding cleaning of the internal wiring and components please guys.
After many years of being in a smokey environment everything is caked in a yellow haze which I would like to remove if possible?
Posted: Fri May 09, 2014 6:14 pm
Don't you know that thick nicotine stains add the best tone?
There no easy + safe way to clean the inside components. Maybe a toothbrush and a (very) little warm soapy water -- followed immediately by a thorough dry out.
Posted: Fri May 09, 2014 7:13 pm
good call Mark,
a toothbrush and a leaf blower to be safe.
I prefer not to use any liquid. That is mojo.....the amp earned it!
Posted: Fri May 09, 2014 10:27 pm
by issmol
Ha! Ok... ok... I hear you both. I will leave the insides and the smokey tone well alone..
In the great scheme of things I know this isn't important... but I would like to buy the correct replacement carry handle, two chicken head knobs, chassis securing bolts and a replacement rear lower panel.
Any pointers in that direction would be greatly appreciated please gents??
Posted: Sat May 10, 2014 4:28 pm
by issmol
Today = Heat shield cleaned. Valve cans cleaned. Purples loaded into WEM and plastic magnet cap reglued. Grille cloth steamed with a modified Black & Decker wall paper stripper.
Clean photos will be uploaded here.
http://s72.photobucket.com/user/philm0l ... /Combo%203
Posted: Mon Jul 21, 2014 12:10 pm
by issmol
Thought I would give you a quick update guys.
I received the amp back off my local tech over a week ago now and I have been playing it through a 2 x 12 WEM loaded with the Purple fanes. (damned nice it sounds too!)
Still lots to do in terms of recap etc but I thought you might like to see a mod that has now been snipped out by my tech....
Any ideas as to what it would have achieved?
Posted: Wed Jul 23, 2014 9:48 pm
The 1M5 resistor was originally 1M. I'm not sure why one would change that
unless the modder empirically determined that the change in voltage made for more clean headroom (or the opposite).
The caps across the Master Volume were put in to reduce brightness.
Posted: Thu Jul 24, 2014 10:05 am
by issmol
mhuss wrote:The 1M5 resistor was originally 1M. I'm not sure why one would change that
unless the modder empirically determined that the change in voltage made for more clean headroom.
Thanks Mark, yes the 1M5 was added for more clean headroom as there was a distorted sine wave being produced with the 1M in place apparently.
