Spitty Mod, do all the 2 input need it ?
Posted: Sun Feb 22, 2009 5:18 pm
i have a 78' 2 input DR504 that is stock except i replaced all teh electrolytic capacitors and installed teh M Huss bias mod.
i have seen teh "Spitty" Mod on that website but i don't have the feeling mine has that problem, especialy when i hear the "before" clip of teh normal channel on M Huss website.
this clip sounds like an old fuzz that is not working that well or pushed over the top with gain (makes compression, what's called the blocking distortion from what i understood) and my amp with normal channel and master volume pot turned to max don't seem to have that spitty / blocking distortion sound although it has much gain already on teh normal channel (i pu the presence and treble on 3) .
the bright channel really bears its name as it is really bright with an SG and 68' T-tops or with an SG with actual p90's, even with the presence pot and treble turned nearly all teh way down !
this bright channel really has tons of gain , more than the normal channel.
so i was wondering if all these late 70's 2 input DR504 (and maybe DR103 as well) amps need that spitty mod or if some already sound right from teh start.
the M Huss "before" normal channel clip has a type of tone that is so noticeable that i don't think i could miss it on my amp (i use it with an old early 70's hiwatt 4122 cab with original Fane speakers).
