Mod Hiwat DR103
Mod Hiwat DR103
Is it poissble to mod an Hiwatt DR103 to use it how Slave PA only?
Re: Mod Hiwat DR103
I would imagine it would be possible to wire a direct in to the power section, but....why do you ask?Pinus wrote:Is it poissble to mod an Hiwatt DR103 to use it how Slave PA only?
Are you trying to tandem guitar or bass amps or really use a 100w tube amp for PA? Even the Grateful Dead gave up on valve powered PA Systems
Re: Mod Hiwat DR103
Just put an insert jack between the treble control and the master volume.
Re: Mod Hiwat DR103
ehehehI would imagine it would be possible to wire a direct in to the power section, but....why do you ask?
Are you trying to tandem guitar or bass amps or really use a 100w tube amp for PA? Even the Grateful Dead gave up on valve powered PA Systems.
Thank you! Very easy at last, i tried today and work greatJust put an insert jack between the treble control and the master volume.
