Help with head match to a LS412 cabinet
Can I connect a Hiwatt 50 Crunch solid state head to my 80's LS412 cabinet? It does not say what ohm the cab is, but the speakers are 16 ohms/75 watts each. The head rating is 4-8 ohms. If I cannot connect the Crunch head, what Hiwatt head connects safely to the cab?
Re: Help with head match to a LS412 cabinet
The cab is almost certainly 16 ohms, but you still can connect the head safely. It'll just put out less power then it would at 4 or 8 ohms.
Matching output and input impedance is more important with amps with tube output stages.
