how to identify a Dave Reeves wired amp V. a Harry Joyce
Re: how to identify a Dave Reeves wired amp V. a Harry Joyce
The mil-spec way to do it from under the board is to make sure the wire comes out the top of the turret and bends over, so it can be physically inspected from the top of the board. The HJ ones I've worked on have been this way. Despite best intentions, this is not always obvious once the component has been laid on top and soldered in.
Bossco
Post by Bossco »
I noted pictures are missing on various threads ... such as this one. Now I wish that I had saved them to my PC. Are they forever gone?
Bossco
HIWATT DR-103, DR-112, SE-4122
Diezel VR4S * Rivera S120 * Dr. Z Maz-18 Jr
Eventide+AnalogMan+ Effects
No, I need to update my village photos account. I will get them back up!
Bossco
Post by Bossco »
Dr.HIWATT wrote:No, I need to update my village photos account. I will get them back up!
I must be going senile ... thought I'd posted a thank you for getting the photos back up, but apparently not. So I'm thank you now.
Interestingly enough there's an alleged Harry Joyce signature DR-103 on ebay right now.
Anyway to know authentic, or not, with DNA or carbon dating? ;-)
Bossco
The HJ signature, is NOT RARE.
His shop did wire more than any other subcontractor. They are the most common of all the real HIWATTs.... :roll:
I crack up every time I see ebay sellers promoting their amps like that!
marantz1300
Post by marantz1300 »
My 73 Dr112 has wires under board and no ink spots. Maybe Harry started the job and Dave finished it on the day this was built. Image
I am pretty sure that Dave Reeves removed himself from the routine building by 1972 or 1973. He did more Research and Development and custom "one-offs" for artists. HJ electronics or another subcontractor most likely built your PA head.
marantz1300
I was just kidding. :D
Tonic Amps
Post by Tonic Amps »
What is the latest known HJ wired amps? I ask as I just picked up a 1980 Hylight (inspection date 31-1-80) DR103 that has blue marker on all the solder joints and wires coming from under the board. It's kind of an odd ball amp as it has all the cap cans inside the chassis, retains the heat shield, and only has 4 noval sockets/holes. This was pretty much near the end of Hylight's existence, so I am a little curious.
Harry continued to wire for HIWATT till the end of Biacrown, the end of 1984.
Tonic Amps
Thanks.
When did Hiwatt start using PCBs? Was that purely in the Biacrown era? Also, did Reeves and crew start putting marker on their solder joints at some point?
DR started using PC Boards in late 1980. I don't know exactly when Hylight builders began using felt tipped pens or the degree of regularity to which they used them. Other subs used the pens also, but HJE was the largest subcontractor.
Tonic Amps wrote: When did Hiwatt start using PCBs? Was that purely in the Biacrown era?
50 and 100 watters got PCBs around April of 1980. DR201's used turret boards through the Hylight era.
nice work Dave!
Dr.HIWATT wrote:nice work Dave!
Just noticed that my SA112 is the first PCB listed in Mark's registry. There are a couple of amps above it that don't declare one way or another.
Unless I read the scribbling wrong, it was inspected 15/4/80.
