Here's a Swarty-modified Fender Bassman that originally had the AC568 circuit, so I sent it out to Tim Swartz for him to work his mojo on it.
Specs:
New Filter Caps
Based on a Blonde Bassman/JTM45 marriage (with Tim's modifications)
50 watts, single channel amp with hi and lo inputs, gain switch, and a tone stack switch.
The tonestack switch is footswitchable (footswitch not included).
Has Treble, Mid, Bass, Presence, Pre-PI Master and Post-PI Master.
Reviews can be read here: http://reviews.harmony-central.com/revi ... Tim+Swartz
Only real cosmetic damage is to the back panel, prior to when I received the amp.
Don't worry, a tube isn't missing, the preamp only uses 3 tubes (I assume one for channel, one for gain switch, and one for PI)
If you're interested in buying and need to see a gutshot, I'll send you one, I didn't want to post it publicly for Mr. Swartz sake (cap values are painted over in gold paint anyway.)
SOLD!
Thank you for the interest!
