I just got one that was completely pulled out of the chassis!
Here is one way to fix it.
Use a hardened piece of steel and two small C clamps to support the loose hank bush.
Using a ball pien hammer, gently work the edges of the hank bush into the surrounding steel of the chassis.
once finished the hank bush should be firmly secured.
Good Luck and Happy HIWATTing!
