The only changes were:loylo wrote:Did you convert the whole preamp to the mid 70's one, or just the resistive mixer on V2? I wonder if I'll change the resistor and caps on the cathode of V1 from 1K5+150µ to 2K2+47n...
I'd also like to know when you plug the OCD whether you put a bit of drive with the pedal or just boost the amp olumewise (clean boost)?
1) undoing the gain mod (V2B was already unused due to this mod)
2) adding the 470k resistive mixer.
No components were removed or replaced. V1 is shared cathode with 1k5 + 150µF. V2A has a 1k cathode resistor, no bypass cap - same as the early '70s circuit.
I usually set the OCD as a clean boost (clock face references): volume 3:00, drive 7:00-8:00 (barely up), tone 12:00, LP setting. If I'm playing someplace where I can't crank the master volume I'll occasionally kick in slightly more boost/overdrive for leads from a Robin Trower Overdrive or Jekyll & Hyde pedal.
But if I'm able to wind the master way up it doesn't need any boost pedals, except perhaps for higher gain solo stuff. I can't imagine ever needing more gain than that.
