the FL112 arrived today, safe & sound. now that I've got it in my hands, it appears there has been some internal work done (see pics). the amp actually sounds great. big & chimey w. tons of headroom. I popped in an EV SRO to demo it & it's a great fit (came unloaded).
the amp is running super hot, however. the prev. owner "fixed" this, by adding a fan ; ) it's running so hot, that the amp smells like hot wax, & the rear vent is pretty hot to the touch.
if it's a just a matter of being under biased, can I pop in some new tubes w/o burning them up?
* aside from the few changed caps, anything else stick out? (I did notice a few spots that were rewired. master vol. pot has been replaced).
* there are 2 add'l holes in the chassis leading me to believe this was once modded, & then undone (see upper LH corner preamp section. other hole was on rear)
* also, does this amp have the canadian mod (is that the yellow wire?) or need the de-fizz?
I'm not an amp tech, by any means, but not afraid to solder either. any help would be greatly appreciated.
more pix here: http://s86.photobucket.com/albums/k117/ ... wattFL112/
thx,
al
