louis wrote:Is it a problem to plug 2 different ohmage cabs with a 100 watt head ? one 8 and one 16ohms
Not the ideal situation. The resulting load would be around 6 ohms (assuming they're connected in parallel to the amp) and there would likely be a volume difference between the two cabs.
Hold off until the good Professor weighs in, but I think it's generally better to run higher, rather than lower impedance in relation to the selector setting.
Not an ideal setup... 5.333 ohms. I'd set it for 4 ohms. You'll probably lose a little volume and get a very slightly different frequency response from the amp compared to a "perfect" match.
And OldSchool's right - the eight ohm cab will get about 2/3 of the total power, so make sure it can handle it.
There's no ideal solution to that pairing, which will end up around 5.3 ohms total in parallel. I'd suggest the 4 ohm setting as that is the closest match. N.B. The 8 ohm cabinet will absorb about twice as much power as the 16 ohm.
PS. Total impedance in parallel = 1/(1/Z1 + 1/Z2) = 1/(1/8 + 1/16) = 5.33
If I had my DR103 (selector on 16 ohms ) with my 16ohms cab , would I solve the problem by sending a signal to a slave amp
with it's selector on 8ohms going to the 8 ohms cab ?
louis wrote:
If I had my DR103 (selector on 16 ohms ) with my 16ohms cab , would I salve the problem by sending a signal to a slave amp
Yes. In that case, both cabs are matched up with their respective power amps.
You know that I want to build or have someone buid me a Sap with KT88's ,
Could this amp have a switch in the back that would cancel the pre-amp and become a slave if I need it to?
