To make a long story short, I have a '78 DR504 that is proned to sound fizzy and farty. I have tried to see what's going wrong with my amp since 2005 and explored different boards (vintageamps) asking what's going on, to Professor Huss among others! I've searched for bad tubes, bad solder joints, bad ground connection, parasitic oscillations, etc. But nothing had improved.
In the late 2008, Professor Huss came with his spitty mod, pointing the problem is blocking distortion, as I learned I am not the lonely guy facing farty sounds with Hiwatt. Actually, there is blocking distortion going on in my amp too. So I tried the spitty mod, and it has just slightly worked. It's a band-aid, I still hear farty sounds as I dime the volume.
I've also tried to convert the late 70's preamp configuration to the mid 70's one. It improves the sound futher more, but the level of gain of the amp decreased a lot. That's not what I want, I want to enjoy the classic hiwatt crunch sound. So I'd plugged a clean boost in front of the amp to match the level of gain of the late 70's circuitry, and I hear the exact same amount of blocking distortion going on.
I was totally fed up with that amp, so I've let it alone for one year and a half.
Now I see we have learned a little more. So people seem to face the same symptoms, others not:
I am surprised that some hiwatt fellas have the chance to own a two-holer that don't fizz. Whether they don't hear the problem (How could it be? It's so an unpleasant distortion, that you would know it's not a natural crunch!), or it's not a design mistake. I mean, if it's a design mistake, all the two-holers may face the same problem.mhuss wrote: I still haven't figured out why, say, 20% of the two-holers don't fizz. Any of you folks with stock ones that sound good, I'd love to see some gut shots of your amp.
At first sight, I thought it's a design mistake because the first stage of the preamp has a lot of gain. And when the volume is dimed, it sends all the signal to the grid of the second stage tube, without any attenuation nor grid-stopper resistor. So because of the RC constant of time of the normal channel, it is aimed to face blocking distortion problem. I've tried to search solutions that are not only about applying a band-aid, like the two 470K (or even 1M) which doesn't totally cure the problem for me. It implies to radically mod the amp, witch sounds like blasphemy. My technical knowledge is far too limited to find a real solution. And I don't know if I have the guts to hack the amp!
So now, why 20% or so of the two-holers seem to not fizz?
I wonder if those who made the statement that they have a stock two-holer which don't fizz, have tried to peg the volumes, and so if it sounds perfectly correct. Same question to those who are plenty satisfied with the spitty mod, or the conversion to the four-holer type of circuit.
Can the four-holers be really really pushed hard, helped with a clean boost, without becoming spitty?
If so, does the problem really is about blocking distortion? Could it be another problem, like a layout mistake (like some of the connection under the preamp board) which makes most of the two-holers sound spitty (while for some reason some of them don't), or an electronic part, like the volume pot, which becomes defective over the years (while, say, some of the amps are built with long lasting pots)?
It would be great if we can resolve that mystery!
The hiwatt is cool for its clean sound. But I'd really like to enjoy the crunch. As is, it's like owning a Plexi and don't be able to make it crunch!
