I've been working on my FL112. ordered the recap kit here & just fin. the filter caps (no one told me mil. spec meant they tied them in knots before soldering!
I'm on to the preamp tagboard. just want to bring this back to orig. specs. there are a few sections (both ends) that had a little work done. my knowledge is limited, & I've been trying to piece together what I can from mark's site, other pix, & my cursory knowledge. some things are easy for me to spot & replace (ie. replace orange drops w. same value sozo's, as noted on schem.). others not so much...
here are 3 pics of my tagboard.
here's a pic of a late '70s 2 input tagboard that appears to be stock:
link to GIF on mark's site:
http://www.hiwatt.org/Layouts/Tag3.gif
when you compare my board to the other examples, it appears that a few things are amiss.
- specifically, the 1st 2 positions on the L (cathode resistor/cap?) seem out of order.
- also the last position on far R, should mine have the resistor & cap? (you'll not mine has both in the full pic, but the resistor leg broke. I wasn't sure where to go from here, as info seems to vary...)
I know all of this may be hard to tell from this limited info, but if you can point me in the right direction, I'd appreciate it.
still learning,
al
