Here's the place to discuss Vintage Hiwatt Conventions; past, present & future!
Zells
Posts: 160 Joined: Sun Feb 01, 2009 1:52 am
Post
by Zells » Fri Aug 27, 2010 1:35 am
This is a very cool early Hiwatt with serial # in the 4XX range (1968?) with no master volume. Notice the odd placement of the Bulgin socket, the smaller vent on top, and the longitudinal stripes on top. Wait, why is the voltage tap selector pointing to '225V'?
Zells on Fri Aug 27, 2010 2:01 am, edited 1 time in total.
Zells
Post
by Zells » Fri Aug 27, 2010 1:41 am
This a 7XX serial # DR103 built in 1969 and used by the band Soft Machine. Is that a slave jack next to the serial tag?
Zells
Post
by Zells » Fri Aug 27, 2010 1:45 am
1969 Hiwatt CP103. It has the four input volume knobs and lacks a 'middle' tone knob just like the CP103 amps used by The Who. There seems to be no vent on top and no bulgin socket.
Hiwatt Bob
Posts: 148 Joined: Sat Dec 01, 2007 10:48 pm
Post
by Hiwatt Bob » Fri Aug 27, 2010 3:12 am
thanks for the pics Zells!
who's Plexiglass Hiwatt is that?
Posts: 2060 Joined: Wed Nov 14, 2007 9:24 pm
Post
by OldSchoolDave » Fri Aug 27, 2010 3:26 am
That now resides in its rightful place: Hiwatt Valley!
Zells, several of Dr.Hiwatt's amps run at 225v. He's got a voltage regulator for that very purpose.
Zells
Post
by Zells » Fri Aug 27, 2010 1:45 pm
Do these amps run properly at 225V only, or is this voltage chosen as a matter of preference?
Posts: 2675 Joined: Wed Nov 14, 2007 8:51 pm
Post
by Dr.HI-TONE » Fri Aug 27, 2010 1:51 pm
I have a handful that do not have 105, or 115 taps. only 225, 235, 245.
There is no tonal effect on running an amp on 125 v. 225 unless there is a descrepency between the wall voltage and the tap on the transformer.
ie. an amp set at 115v with voltage at the wall supplying 126v. compared to an autotransformer deliverying a steady 225 to an amp set at 225.
Zells
Post
by Zells » Fri Aug 27, 2010 2:32 pm
Dr.HIWATT wrote: I have a handful that do not have 105, or 115 taps. only 225, 235, 245.
That makes sense for an exclusively European customer base. I'm guessing that these amps are all pre-1970.
Post
by Dr.HI-TONE » Fri Aug 27, 2010 2:34 pm
yes, most of mine are 1970 or older.
Posts: 1440 Joined: Thu Nov 15, 2007 5:40 am
Post
by mhuss » Fri Aug 27, 2010 3:54 pm
Dr.HIWATT wrote: ...compared to an autotransformer deliverying a steady 225 to an amp set at 225.
Hmm, have you ever tested these (actual output voltage under load)? Or do you just "trust them?"
Post
by Dr.HI-TONE » Fri Aug 27, 2010 4:00 pm
I tested one of the two a year or so ago. it was accurate.
buster
Posts: 54 Joined: Wed Nov 21, 2007 4:08 pm
Post
by buster » Sat Aug 28, 2010 2:12 am
Glenn Cornick messing about.
Glenn's invisible bodied guitar.
Some of the gear on show
Post
by OldSchoolDave » Sat Aug 28, 2010 2:13 pm
I KNOW you took more pictures than that, buster! Let's see 'em!
How was the flight home?
buster
Post
by buster » Sat Aug 28, 2010 3:31 pm
The flight home was very pleasant thanks Dave.
Mark looking for the rest of the band.
There they are.
buster
Post
by buster » Sat Aug 28, 2010 3:39 pm
Dave heading for his "special" room in the corner of the hall.
Another Hi-Tone display shot.
Dave and Glenn Cornick on a boat after the convention.
