Finally got the probes in. I'm guessing the Mains switch has gone bad, as the readings from the bulgin plug are fine (err, within reason, our AC runs a tad hot in this building, I suppose: 120VAC). Before the switch, voltage is fine, measures 120VAC. Measuring after the switch I get 40VAC with the mains switch "off," with it "on" I get no reading whatsoever. This also confirms my readings from the AC mains selector: 40VAC with the mains switch off, no reading with it on.
Bad switch?
I also noticed that the caps are starting to get those lovely little bulges. Guess it's time. I take it this is the kit chosen by experts the world over?
