Fane Crescendos 12E
Fane Crescendos 12E
Hi everyone !
I've posted some pictures of some Crescendos I have here ,some of you posted questions and got some answers
about them but no pictures so this is for the record.
I am fortunate enough to know someone near me who has been selling and reconing Fane
speakers since the early 70's and Dave and Doc are right !
they were intended for pa reinforcement.
He told me that they are still high quality speakers and have a little more balls and headroom than the A's , also one of his
customers have used them in an old Twin Reverb amp and it's jaw dropping!!
He has no experience of someone testing them in a Hiwatt cab though and I never had
the chance to try them myself.
Louis :wink:
louis 022.jpg (99.14 KiB) Viewed 2970 times
louis 020.jpg (218.08 KiB) Viewed 2972 times
louis 005.jpg (232.95 KiB) Viewed 2972 times
louis 004.jpg (184.77 KiB) Viewed 2972 times
Re: Fane Crescendos 12E
Thanks for posting those pics, Louis!
Those have the non-standard bolt patterns / frames Fane employed in later years. The would not bolt up to most rear loaded cabs. Front loaded cabs should be fine, though.
Youre Welcome Dave !
If I have a chance to put them in a cab one day , I will post back
with an opinion on how they sound .
BTW , the speaker tech was able to get rid of a lot of deep bumps
on the dust caps by putting a masking tape and pulling it fast,
he did it several times and it worked , I still have a few more shots
to do to get the dust caps back to shape.
Take care!............................Louis :wink:
Hi !!
Could I order a Hi-Tone 2x12 cab for those to try,
and could it be ordered front loaded ? :roll:
And last ,do I need the special clips for those or screws will work fine ?
I dont have the clips and dont have the right screws for this,
where can I get them ?
Regards!..................Louis
those could be loaded from the rear.
Is there a particular reason you want to load them from the front?
OldSchoolDave wrote:Thanks for posting those pics, Louis!
Those have the non-standard bolt patterns / frames Fane employed in later years. They would not bolt up to most rear loaded cabs. Front loaded cabs should be fine, though.
Yes Doc !..because Dave says so!
Oops, I missed that.
I wish I had one of those to use as a template to place new mounting studs with!
What is the zip code in Hiwatt Valley, I'll probably send
them to you if shipping is reasonnable.
I never had a chance to try them so you could
give them a ride in the same time !!
I can compare them to Crescendo "A" from 1973
:D
You should just drive down, we can load them up and you can take your cab home. It may work out to be cheaper?????
Dr.HIWATT wrote:47201
:D
It would be great like you say to compare them with the A's because
no one knows how they sound exept for the Fane distributor from the 70's near where I live
that said that they have more headroom than the A's.
And if they dont sound good ,you could keep the magnets as
paper holders on your fridge !! :lol:
I could have the cab ship in Vermont at a friend of mine who
often comes to Montreal so no problem !
I'll let you know !
the Vermont connection would definitely save you some $$$
Just let me know!
Primakurtz
Post by Primakurtz »
I have them now - thanks, Louis!
I have one installed in the bottom of an older Mesa vertical 2 X 12". They are meant to be rear-loaded, but I don't have a cabinet with the necessary wider bolt pattern. I decided not to mess up my early-70's Hiwatt cabinet...
Sound? Terrific! They remind me of a good JBL - balanced, with plenty of bright high end, but not annoyingly shrill. Very warm and a bit "crunchier" than modern Medusas. Good speakers for rawk.
I will probably keep the one, and sell the other, unless someone just has to own them both. 8)
