DR504 Noise Identification
guitman
Post by guitman »
My DR504 has this intermittent popping noise that appears every minute or two. Louder/softer with master volume.
Nothing plugged in to amp, happens with preamp volumes turned down or up.
Cap job last year, they still look in good condition. I replaced power tubes last week, but the issue persists. Other than that, amp works great.
Here is an MP3 of the noise: https://drive.google.com/file/d/0B7Gmbc ... sp=sharing
Any ideas?
Re: DR504 Noise Identification
I couldn't get your google drive file to play.
Try all the usual things, remove and re-seat all the preamp tubes. If you have a known good spare, try swapping out the preamp tubes one at a time. You could also look at the inside of the chassis in a darkened room to see if you see any flashes anywhere that correspond to the popping.
