BEST BOOSTER FOR HIWATT's ?
Posted: Fri Mar 19, 2010 3:09 am
by louis
I Love the Kerrang sound of my Hiwatt and also like when it's pushed a little !
Problem is that the tone changes when I boost the signal with a pedal ,
too much mids or too much highs or compession .I would like a pedal that would push
the amp without changing the tone .
Any opinions on a good booster that would mate with a Hiwatt ?
Thank's!.......................Louis
Re: BEST BOOSTER FOR HIWATT's ?
Posted: Fri Mar 19, 2010 4:00 am
by mikhailwatt
Fulltone FatBoost 3
Fulltone OCD v.4
Both fairly neutral-sounding when used for a clean-ish boost.
The FB3 doesn't have as much boost, but it pushes just enough. Volume high, drive about halfway.
The OCD has a lot more boost potential, volume about two-thirds to three-fourths, drive low on the LP setting.
I've tried a TS-808 clone to good effect with single-coils, not so much with humbuckers. Definitely not a neutral pedal.
Posted: Fri Mar 19, 2010 4:10 am
by louis
Thank's MIK !.......Is there some compression on the OCD or it sounds open ?
I had a Fulltone Fulldrive once and it was too much compressed so I'm afraid to get a Fulltone now.
Posted: Fri Mar 19, 2010 4:35 am
by mikhailwatt
louis wrote:Thank's MIK !.......Is there some compression on the OCD or it sounds open ?
Sounds open to me, as long as you keep the drive down. It's nice as an overdrive too, but I don't use it that way.
Mark has some OCD + DR103 clone clips on his site.
The FB3 sounds like the amp, but more. It was designed to push the front of a vintage amp.
Posted: Fri Mar 19, 2010 12:42 pm
by Zells
D*A*M Red Rooster germanium booster. There may be a long wait-list for buying one new.
http://www.stompboxes.co.uk/Rooster.html
Posted: Fri Mar 19, 2010 12:46 pm
by thefatcyclist
Hi
Checkout Youtube clips by a chap callled Clyde67. He uses a booster for his DR504. Check out his Young Lust clip especially and read the discussion thread about that clip. He uses a boost to produce breakup, pretty well in my opinion.
I have tried a ButlerTube Driver on low gain as a boost with some success and its brilliant for dirt as well.
J
Posted: Fri Mar 19, 2010 1:05 pm
by louis
I found this from the same guy ,he uses an Ego Booster ,recorded over a backing track.
http://www.youtube.com/watch?v=-QbC78ep ... re=channel
Also ,here's a demo of the 4 versions of the Fulltone OCD ,thank's Mikhail !
they do sound good but why 4 versions ?
And they all sound different ,seems like they cant make up they're mind!
http://www.youtube.com/watch?v=QnPzxj5M ... re=channel
Here is something I think would probably work good with a Hiwatt, doesn't color the tone too much ,
it's rich and full and based on an Echoplex Pre-amp circuit.
Let me know what you guys think!
http://www.youtube.com/watch?v=4L01JZs0Iig
Posted: Fri Mar 19, 2010 7:35 pm
by Tripower455
I used to use a Barber LTD, until I got a Catalinbread WIIO......
Whole 'nother ballgame! Run into a clean Hiwatt,it makes it sound like a cranked Hiwatt.........
Posted: Fri Mar 19, 2010 11:55 pm
by louis
Tripower455 wrote:I used to use a Barber LTD, until I got a Catalinbread WIIO......
Interesting Tripower ,lol ! Hiwatt in a box!
http://www.youtube.com/watch?v=kuPU27-T0fM
Mikhail....think that your Fat boost would be a very good choice also without changing the tone color.
Louis.......
Posted: Sun Mar 21, 2010 12:00 pm
by hohohiwatter
i usually run a dha vt1 valve overdrive with a ecc82 (for milder drive) set so the vol is the same but so it just adds a slighly thicker bit of ovdr crunch (really nice n warm) in2 a byoc tri booster in2 a carl martin hydra boost. i use the tri boost mainly for the treble boost, but the carl martin hydra boost, i find is a great boost, no colouration just gives u what u've already got but more louderer! (upto 22db, i think) an of course the more u boost it will add a bit more crunch, but no eq that i can hear.
give it a go i picked mine up 2nd hand off the bay for about 45/50quid a couple of yrs ago. oh an its also about the size of a phase 90, mabe slightly smaller.
