'80 DR-504 warm up
'80 DR-504 warm up
Somebody pinch me? I just picked up a DR-504. The tubes don't glow and the power light is off in Standby. Is this normal? Should I care? Works fine with the Mains on. Thankyouverymuch.
Re: '80 DR-504 warm up
OK. I think I've been doing this backwards on my other amps for a LONG time. There is clearly a lack of consensus on the web and another group contends it's not necessary at all, but I digress. You turn the mains on FIRST and THEN the standby after an adequate warm up...
Cheers
Cheers
That makes much more sense.
Always turn the Mains "on" first to let the tubes warm up.
Then turn on the standby switch to play.
