90s or 00s era Hiwatt (and Fane speaker question)
Hiwatt n00b
Post by Hiwatt n00b »
Hi everyone, first post.
I have a couple of questions that hopefully someone will be able to help me with.
I bought a Hiwatt Maxwatt G100R (I think that it is also known as a G100 112R) and I am trying to find some information about it (or a manual). There is pretty limited information about it out there.
I know that it is a 100W, 2 channel solid state amp, but I cannot find out much beyond that...
The speaker in it is a Hiwatt "high efficiency heavy duty" speaker. Designed in England, probably made in China, but I do not know what that means in terms of specs. It has GSP-12/175-8 printed on it.
I think that this code may translate as: 'Guitar SPeaker'-12 inch/175W-8 Ohm, but I have seen others claim it to be a 100W speaker. Picture attached.
GSP-12-175-8 - Copy.jpg (46.01 KiB) Viewed 10431 times
I am considering replacing it with this: https://roostamp.com/products/fane-hiwa ... ar-speaker
Do you reckon that I'll see much of a difference between these two speakers? Is there something else that may be a better option?
I appreciate any info that people can provide. This is my first Hiwatt amp, so I have a bit of a learning curve ahead
Re: 90s or 00s era Hiwatt (and Fane speaker question)
Welcome,
"175" might also indicate voice coil diameter
I don't think buying the speaker you propose would add much of anything; I think the newer HIWATT/Fane speakers may be manufactured in China as well if that matters to you.
