How would you describe the sound of Fane spearkers compared to, lets say: Celestion V30s?
(I´m using the V30´s as an example as most people are familiar with their sound)
I´m using Celestion Cenurys (Neo magnets) together with an amp similar to a Hiwatt and it´s hard to get a warm sound out of them...
With other amps (lower wattage/more compression) they´ve been just fine.
V30´s have a softer high end but a more pronunced high midrange.
Are the Fanes "dark sounding" speakers?
(I´ve sometimes seen them described as beeing "full range-speakers", but I do not need anything with too much high end right now)
Thanks.
Fane/sound
Fane/sound
Re: Fane/sound
The Fane Sound can mean different things to different people. And, as we learned in the Speaker Shootouts at the 2007 & 2008 Vintage Hiwatt Conventions, even the Fane models themselves have different tones.
To me, a good vintage Fane has all the woodiness of a Celestion Greenback, but with more fullness and chime. They do not break up as easily, providing a lot of articulation. Oh, and LOTS of punch!
I've never been a huge V30 fan, so I can't speak directly to that comparison (even though the V30 is just supposed to be a higher powered Greenback
That's my take. As I said, it's in the ear of the beholder...
Re: Fane/sound
My Fanes sound a bit darker than a greenback. I have a '77 Marshall cab with blackbacks that is the ultimate "go to bottom. My '78 Hiwatt bottom has incredible low end and and sounds darker unitl the volume gets up there, then the high end comes out. The do have less breakup. I don't have vinatge 30's but have alot of Celestions and scumbacks. I always seem to use the blackbacks or the Fanes.
Re: Fane/sound
Just curious: Do your blackbacks have 55Hz or 75Hz cones?JR wrote:I always seem to use the blackbacks or the Fanes.
