does any1 no the difference between crescendo A & B?
- hohohiwatter
cheers
cheers
- hohohiwatter
Re: does any1 no the difference between crescendo A & B?
come on there must be some 1?
my guess is that 1' a guitar or bass an the other p.a.?
or just guitar or bass?
an i've seen some that r 75w i thought that they only came in 100w. it seems the crescendo range was bigger than i thought. i thought it was just 1 type of fane speaker but it seems that there is quite a few different types in the range.
There doesn't seem to behohohiwatter wrote:come on there must be some 1?
I have seen pictures of Crescendo A's with two different label types, which would seem to indicate different eras. I have also seen photos of PA speakers with the Crescendo designation. Fane, during some eras, did use "B" as a designation for Bass. I wasn't aware of a 75 watt version and was working under the assumption that all Crescendos were 100 watters.
The more we learn, the less we know...
OldSchoolDave wrote:There doesn't seem to behohohiwatter wrote:come on there must be some 1?. If someone does know, they're not active (or sharing) on the internet forums. Precious little documentation on vintage Fane speakers to begin with, let alone on that elusive model.
I have seen Crescendos that were 100w. with Aluminum dustcaps, but weren't marked A or B.
I didn't know a 75w version existed.
- hohohiwatter
yeh recently seen 2 that r rated 75watts,16ohms and 20,000flux density '72 (i think, but its hard to make out the label) with grey cloth dust covers.
IF those cones are original, it would make sense that "B" Crescendos were designed for Bass applications (including woofer applications in Sound Reinforcement).hohohiwatter wrote:yeh recently seen 2 that r rated 75watts,16ohms and 20,000flux density '72 (i think, but its hard to make out the label) with grey cloth dust covers.
Not sure how responsive they'd be for guitar. Some guys (myself included) like using bass speakers for guitar - in certain circumstances. Others find the stiffer cones more brittle sounding.
Will that seller provide higher quality pics of the stamps and any cone codes?
- hohohiwatter
have asked, will post when i get a reply.
it seems a bit odd tho that iff they r for bass that there rated less at 75w?! shurly for bass u'd want high as poss. like the 100w 1's.
i dunno,
could u see the picks i tried to put up it just sez image for me
i dunno,
I would suspect they have the same Voice Coil as the "A", but rated lower to compensate for the bass abuse
My thoughts exactly! Lower frequencies create more stress, therefore the reduced (advertised) power handling.Dr.HIWATT wrote:I would suspect they have the same Voice Coil as the "A", but rated lower to compensate for the bass abuse
- hohohiwatter
ahh well that makes sence.
prob wood sound nice in a 4x12 with 2 more hiwatt fanes or sound city or summit.
bit o bright with a bit o bass
OldSchoolDave wrote:My thoughts exactly! Lower frequencies create more stress, therefore the reduced (advertised) power handling.Dr.HIWATT wrote:I would suspect they have the same Voice Coil as the "A", but rated lower to compensate for the bass abuse
Great minds!
Indeed they may sound great with a pair of something else.
- hohohiwatter
ok boys heres some pics
for some reason the only out of focus pics r the 1's of the labels!!
- cres 4.jpg (30.09 KiB) Viewed 3804 times
- cres 3.jpg (30.65 KiB) Viewed 3804 times
- cres 2.jpg (38.53 KiB) Viewed 3804 times
- cres 1.jpg (45.23 KiB) Viewed 3805 times
hohohiwatter wrote: for some reason the only out of focus pics r the 1's of the labels!!
Hard to tell more from those photos. It looks as though some of the writing has been gone over with a Sharpie at some time. Not sure why. They appear to be the genuine. Just hard to tell specifics with the blurry pics. Has he provided cone codes?
- hohohiwatter
yeh i've asked about 1 of the labels seems to have been erased then appears to be rewritten this is what they sed,
The stickers are original as from the shop -just a little unclear. The serial numbers are ; 3371 and 0672. As far as I can make out,the guy with rubber stamp has overdone it on one speaker, cheers.
the other 1 seems to have the stamp print intact, maybe for some reason the other label got damaged an they just copied over the info?
- hohohiwatter
or maybe the stamped print on the sticker was very faint an some1 decided to make it clearer?
