DR201 Housekeeping
theSeeker
DR201 Housekeeping
Post by theSeeker »
Everything is running clean and quiet, but here are a few questions about my '78 DR201 (6 x EL34).
1. I have a new set of winged C EL34's and after moving them around to balance side to side, I have measured the following:
Plate voltage: 675 Bias Voltage: -37
Left: 32.3, 35.1, 32.9 mA (delta V 1.774/20.2 ohms = 84.0 mA)
Right: 35.1, 35.3, 26.0 mA (delta V 1.679/20.0 ohms = 87.8 mA)
I think the sides are balanced the best I can, my question is should I bother to change the bias resistor or let 'em run hot?
2. My screen grid resistors are all discolored like this:
Should I replace them?
3. It's hard to photograph, but all the caps have a little bump as shown on the center one here:
It is in the exact same place on every one. Do they need replacement?
Re: DR201 Housekeeping
Too hot. I would much prefer if these ran closer to 25mA.
As long as the screen resistors still measure 1k +/-5% they should be okay.
The electrolytic cans need to be replaced.
theSeeker
Post by theSeeker »
Thanks Mark, that leads me to the next question. The bias resistor is 22k right now. I have values of 24k, 27k, etc in increments of 3k. I would like to avoid solder, test, solder, test, so in your experience can you tell what a good increment would be to get close with the operating parameters above?
I take it you have the separate bias winding and two parallel bias trimmers in series with the 22k? In this case it's more of a winding limitation than a resistor value. I'd try something way high (say 100k) and see where that puts you in terms of maximum negative voltage.
theSeeker
Post by theSeeker »
No this one has the alternate configuration, still a separate bias winding but fixed. I see your diagram shows -46V, I only measure -37V right now, so you think it will take a large change in resistance to bring it in?
Probably. You could also try the 1M pot in series that people have used with success on the fixed bias network DR103s.
theSeeker
Post by theSeeker »
I need clarification in the values I posted above measured the cathode current, and by measuring plate current through voltage drop the average is ~3-5 milliamps lower, which I understand is screen current.
theSeeker wrote:Plate voltage: 675 Bias Voltage: -37
So the calculation I am shooting for 0.7*25/675=26mA. This is plate current only right? And I should expect the individual cathode currents to be in the neighborhood of 30mA?
Yes.
theSeeker
Post by theSeeker »
Got it, one 27k resistor and she's idling happily. It sounds awesome, and LOUD! :D
Nice. :)
