This amp has several features or issues that just aren't right.
how many can you identify?
http://www.ebay.co.uk/itm/Vintage-HIWAT ... 4abe2e5f86
not much. You are spot on. From the viewpoint that this amp is from the serial # range 1000-1100, which I am confident, the only issue is that the serial number tag must be unoriginal to the amp.Alnico wrote:The serial number doesn't make sense, but otherwise it looks very similar to DR103 s/n 1097 - HJ style wiring, same board layout with both halves of V2 used, same head box, same chassis, offset s/n plate etc. What am I missing?
