70ies HIWATT cab. Metric threads for speaker bolts?
GoldTopHeaven
Post by GoldTopHeaven »
Hi everybody, I have this 70es HIWATT cab that I'm going to stuff in some Fane speakers. The cab is empty and the bolts to attach the speakers are missing. There's just the thread inserts left in the front panel. I wonder if it is metric or if i would have to look for some brit size bolts. Anyone knows?
Re: 70ies HIWATT cab. Metric threads for speaker bolts?
Sad to admit, by my similar cab is inside a flight case, in storage at the moment :( .
I've not seen a port arrangement like yours before. Here's what my 81-ish cab looks like:
If you have a 1/4" x 20 bolt laying around, I'd give that a try in the T-nuts before shopping for something more exotic. That's just from eye-balling the pic, though.
GoldTopHeaven
Thing is, I moved to an other home and all my tools , U.S. standart nuts and bolts are in a storage. I'm located in Germany, so I'd have to shop from some specialty shop, but since I can't just carry the cab around I'll have to shop by guessing, which I actually hate. The source I know has quite a few nuts in bolt non metric but they're stainless and expensive. I just can't afford buying a huge can of useless nuts and bolts only to possibly find out that they don't fit. But looks like there is no other way. I#m gonna throw the cab into my station wagon and see how fa I get with my shopping. I was hoping s.o. in this forum would know what they are like,....so I remain patient. It's Saturday anyway, so.....;)
Dad3353
Post by Dad3353 »
GoldTopHeaven wrote:Hi everybody, I have this 70es HIWATT cab that I'm going to stuff in some Fane speakers. The cab is empty and the bolts to attach the speakers are missing. There's just the thread inserts left in the front panel. I wonder if it is metric or if i would have to look for some brit size bolts. Anyone knows?...
Good afternoon...
I'd measure the diameter of the thread and look for the nearest 'BA' bolt as a first choice. I'd guess 2BA, a common British bolt (British Association...) used for many years, and rife in the '60s/'70s. Good luck.
PS: You might like to read this, nicely 'tongue in cheek'...
http://vintageamps.com/plexiboard/viewt ... 9&t=103224
Have a good day.
Dad3353 (Douglas...)
GoldTopHeaven wrote:but since I can't just carry the cab around I'll have to shop by guessing, which I actually hate.
Feel around for a loose T-nut (odds are that at least ONE of them is...) and pop it out from the front, with a small screwdriver and (gentle) hammer taps.
Much easier to take the T-nut with you shopping than the cab - or to rely upon "educated" speculation :) .
When done, you can press and tap the T-nut back into place.
GoldTopHeaven
Dad3353 wrote: I'd measure the diameter of the thread and look for the nearest 'BA' bolt as a first choice. I'd guess 2BA, a common British bolt (British Association...) used for many years, and rife in the '60s/'70s. Good luck.
Thanx bunches Douglas, I'll read this
GoldTopHeaven
OldSchoolDave wrote: Much easier to take the T-nut with you shopping than the cab - or to rely upon "educated" speculation :) .
Definitely true Dave. I'll try to do that. Best
GoldTopHeaven
BTW Dave, what kind of speaker did you load into the cab?
GoldTopHeaven wrote:BTW Dave, what kind of speaker did you load into the cab?
That one came to me with Hiwatt Fane 122142's. It's a very good sounding cab :) !
Hope you find what you need .
GoldTopHeaven
Wow, that's very kind of you. Thank you so much.
GoldTopHeaven
All right, finally got the correct bolts from a local hard ware store. Pulled out a receptacle and took it to the shop. Unfortunately they only had them in stainless steel. I was glad to get this UNFE in my city, so with a whopping 30 $ I took them home with the washers.
Anyway the right bolts to go with my cab's receptacles read 10-32-32
Thank you everybody for your kind assistance
Hey !..............very happy for you !
Now you can move on and Rock this cab !
GoldTopHeaven
Yeah, I'll post a video once I get the chance.
GoldTopHeaven
Hmm,..I try to figure out how to mount the speakers. It seems like the front panel is not removable, so I was assuming that the speakers attach as front loaders. But when trieing to do so two things just seem wrong. First the bolt radius is larger on the cab than it is the case on the speakers and second, I wonder how a speaker would damppen since the outer rubber ring of my FANE speakers would be in the front towards the outside of the cab. Any ideas how to deal with that?
