SA212R Question
Casey78
SA212R Question
Post by Casey78 »
Hey guys, quick question. What is the ohms load for the SA212R's? Mine is a 1976 and it has nothing on the back saying. The reason I ask is because I recently picked up a pair of purple back 125155 Fanes. They are 16ohms each. What would be the best way to install them in said SA212R?
Re: SA212R Question
Connect them in parallel.
The two leads coming out of the chassis of an SA212 are from the 8 ohm tap.
FYI, in order to facilitate future chassis renewal on my (former) SA212, I wired those leads to a Cliff Jack mounted on a fender washer in an unused power tube socket.
SA212 Speaker Jack mod.jpg (160.94 KiB) Viewed 1359 times
Cool amp you have! Not many Reverb models around.
Casey78
Re: SA212R Question
Post by Casey78 »
Thank you so much Dave!
It is indeed a very cool amp. And now that i have an actual pair of purple back Fanes it's even cooler!
